First of all, thank you for the fantastic work you’re doing!
I’d like to suggest a feature that would greatly improve the user experience: the ability to embed inserted videos directly into PPTX presentation files. Currently, videos are linked externally, which means users must keep both the presentation file and the video files in the same folder. This creates inconvenience, especially when sharing presentations—users have to compress and send the entire folder, including the presentation and all video files.
Embedding videos directly would streamline the process, making it easier to share and manage presentations without worrying about missing or misplaced video files.
Do I understand correctly that you use Desktop Editors? If so, pelase specify the platform (OS), installation type (DEB/RPM packages, EXE/MSI, flatpak, etc) and version of the app.
Generally, Desktop Editors allow adding videos directly to the presentation.
Yes, I use Desktop Editors—apologies for not mentioning that earlier. The issue occurs across Ubuntu Noble (snap), Arch Linux EndeavourOS (DEB), and Windows 11 (EXE).
To clarify: I can add videos to the presentation without any problems. The issue arises when the pptx file is moved to a different folder than the videos. In that case, the videos no longer play in the presentation.
Created a folder and added a video and an empty presentation to it;
Opened the presentation and inserted the video via Insert tab > Video > selected the video in the same folder;
Saved the file, closed the editor;
Moved the presentation from the folder to another folder;
Opened the presentation from another folder and played the video.
In this scenario the video plays normally. Did I miss anything in the scenario? Can you record the described behavior from any of your devices for better understanding of the performed steps? By the way, if the issue occurs to a specific file, please attach it for tests.
That’s interesting—your solution actually works fine now.
However, I’m still encountering a few issues. Let me clarify:
Your test works perfectly when using the “Start slideshow” button. But in “Show Presenter View” mode, the video plays in the Presenter window but not in the Presentation window. Additionally, if I try to play the video directly from the Presentation window, it still doesn’t work well.
Here you’ll find a recording and a pptx file.
Thanks for the reply. About the issue with the Presenter View: we are aware of this issue and actively working on it. I’ll let you know once it is resolved.
I’m facing the same issue with PPTX and PPTSX files.
I’m sharing a directory on NextCloud V34 to give access to a presentation (online viewer mode only). The PPT viewer works well on Chrome and Safari, but on the slides that embed videos, I don’t have the toolbar to even manually play them. Instead I have a dark square.
Is there a workaround ?
Thanks in advance!
What version of Document Server is being used in your Nextcloud? Also, please note that this topic is specifically related to presenter view, if you have issues with regular slideshow view, you should look for similar topics in this community or start a new topic.
