The models I speak are those you can see on the join picture.
The essential of this menu is to store your Own models what is very difficult !!!
- First you have to found where are they hidden (and they are very well hidden)
- After you need to modify the file name of your model (biginning by “[0]”)
- You have also to play with alphabetic order to see them on the top
- Last If the machine is shared, all the models are mixed which is not a very good idea
A better place for them should be Appdata directory for example or still better ; why don’t you do as WORD and putting the models in an equialent of “/Documents/Modèles Office personnalisés”
Best regards
