Invisible columns bug
Do you want to: Report a bug
Create a document with 2 columns, and resize the font, and only with some random font size a random columns will be invisible.
OS version: ZorinOS 18 (based on ubuntu 24.04)
App version: 9.3.1.8 (x64 deb)
Additional information: example attached
then with a bigger font:
bug2.docx (37.0 KB)
@Nurullo see this also when possible. Thanks
Hi @edurbs,
Thanks for pointing this out! I’m taking a look at this issue as well and will let you know in this thread as soon as there’s an update.
Hi @edurbs,
We have registered this issue as bug in our internal tracking system.
However, there is no exact timeline for its release yet.
We will inform you when we have an update. Thank you for your patience!
