DocumentBuilder version: document-builder 8.3.3.22
Installation method: document-builder · PyPI
OS: MacOS arm
Additional information:
The ToJSON method returns empty string for caption paragraph. The following is an example code to reproduce the result.
# Initialize document builder
from docbuilder import docbuilder
builder = docbuilder.CDocBuilder()
# Open the existing DOCX file
builder.OpenFile("好的.docx", "")
# Get the document context
context = builder.GetContext()
global_obj = context.GetGlobal()
api = global_obj["Api"]
# Get the document
document = api.Call("GetDocument")
# Get element count
elements_count = document.Call("GetElementsCount")
element_count_val = elements_count.ToInt() if elements_count else 0
for i in range(element_count_val):
element = document.Call("GetElement", i)
print(f"Processing element {i + 1}/{element_count_val}")
text = element.Call("GetText").ToString()
print(f"Element Text: {text}")
element_json = element.Call("ToJSON", True, True)
print(element_json.ToString())
print("=" * 80)
The output is:
Processing element 1/11
Element Text: 标题1
{"bFromDocument":true,"pPr":{"bFromDocument":true,"type":"paraPr","pStyle":"711"},"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{"hint":"eastAsia"},"bFromDocument":true,"type":"textPr"},"content":[{"..."}}}
Processing element 2/11
Element Text: 标题2
{"bFromDocument":true,"pPr":{"bFromDocument":true,"type":"paraPr","pStyle":"703"},}}}
Processing element 3/11
Element Text: 正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文
{"bFromDocument":true,"pPr":{"bFromDocument":true,"type":"paraPr"},"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{"hint":"eastAsia"},"bFromDocument":true,"type":"textPr"},"content":[{"bFromDocument":true,"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{"hint":"eastAsia"},"bFromDocument":true,"type":"textPr"},"content":["正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文正文"],"footnotes":[],"endnotes":[],"type":"run"},{"bFromDocument":true,"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{"hint":"eastAsia"},"bFromDocument":true,"type":"textPr"},"content":[],"footnotes":[],"endnotes":[],"type":"endRun"}],"changes":[],"type":"paragraph"}
Processing element 4/11
Element Text: 1) 12312312312312
{"bFromDocument":true,"pPr":{"bFromDocument":true,"type":"paraPr","pStyle":"710"},"}}
Processing element 5/11
Element Text: 2) 12312321322222
{"bFromDocument":true,"pPr":{"bFromDocument":true,"type":"paraPr","pStyle":"710"},"rPr":{"l}}}
Processing element 6/11
Element Text: 3) 21312312312222
{"bFromDocument":true,"pPr":{"bFromDocument":true,"type":"paraPr","pStyle":"710"},"rPr":{"}}}
Processing element 7/11
Element Text:
{"bFromDocument":true,"pPr":{"bFromDocument":true,"type":"paraPr"},"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{},"bFromDocument":true,"type":"textPr"},"content":[{"bFromDocument":true,"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{},"bFromDocument":true,"type":"textPr"},"content":[],"footnotes":[],"endnotes":[],"type":"run"},{"bFromDocument":true,"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{},"bFromDocument":true,"type":"textPr"},"content":[],"footnotes":[],"endnotes":[],"type":"endRun"}],"changes":[],"type":"paragraph"}
Processing element 8/11
Element Text:
{"bPresentation":false,"tblGrid":[{"w":2899,"type":"gridCol"},{""}}}
Processing element 9/11
Element Text:
Processing element 10/11
Element Text: 表 1 test test
Processing element 11/11
Element Text:
{"bFromDocument":true,"pPr":{"bFromDocument":true,"type":"paraPr"},"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{"hint":"eastAsia"},"bFromDocument":true,"type":"textPr"},"content":[{"bFromDocument":true,"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{"hint":"eastAsia"},"bFromDocument":true,"type":"textPr"},"content":[],"footnotes":[],"endnotes":[],"type":"run"},{"bFromDocument":true,"rPr":{"lang":{"eastAsia":"zh-CN","val":"en-US"},"rFonts":{"hint":"eastAsia"},"bFromDocument":true,"type":"textPr"},"content":[],"footnotes":[],"endnotes":[],"type":"endRun"}],"changes":[],"type":"paragraph"}
The result for the paragraph “表 1 test test” is empty. Note: I removed some parts of the JSON string from the output because they are too long.
好的.docx (14.0 KB)
