Can I merge documents directly in OnlyOffice editors?
Hi,
Is it possible to merge two or more documents directly using the OnlyOffice document editors?
For example, can I open a document and insert or combine the content of another .docx or .pdf file into it, without using the Document Builder or any external tools?
I’d like to know if this can be done through the editors themselves, or if there’s another recommended way to achieve it.
Hello @mrmikept
There’s compare and combine feature in the editor: Comparing and combining documents
If I misunderstood your request, please clarify it.
Combining PDFs not working Using Linux Ubuntu:
The PDFs open fine individually - BUT
  1. Opening an existing PDF from a local file does not display the ‘Collaboration Tab’.
  2. Opening a new PDF displays the Collaboration Tab > ‘all file types’ > PDF errors - no import (even tho each PDF opens just fine)
Hello @LegaliMigra
Combining of PDF files is not available yet. Please review this topic:
You can vote for this enhancement and leave a reply.
