ZOTERO
ZOTERO is not working as it should in ONLYOFFICE docs
Hi @Mikihudi, welcome to the community!
Could you please provide more details so we can look into this?
  1. Which ONLYOFFICE product and version are you using? (Desktop Editors — check Help → About, or Document Server integrated with another platform?)
  2. Which Zotero plugin version? (visible in the Plugin Manager)
  3. What exactly happens when you try to use the plugin — does it hang on loading, show an error, insert wrong data, or something else?
Steps to reproduce the issue would help us investigate. Thank you!
OnlyOffice version Community version 9.4.0.129 (x64 flatpack) ZOTERO version 9.0.6 (64-bit)
when i use zotero as plug in in the onlyoffice all teh references i have. does not include year for for example if the authore is Miki year 2026 it will place the citation as (Miki, No date)
Hi @Mikihudi,
Thank you for the details. We are looking into this and have forwarded it to our team for investigation.
We’ll update the thread once we have more information.
Hi @Mikihudi,
We’ve confirmed the issue with offline mode not parsing author/date correctly.
Filed as a bug (internal ref — 83387). We’ll update the thread once it’s fixed.
I have the same problem but Zotero only show (Title of the paper, n.d). It should be (author last name, year), (Do, 2023) for example
Hi @donamhung, welcome to the community!
Thanks for the report — looks like the same bug (internal ref — 83387). Are you on Desktop Editors with Connect to Local Zotero? Which version?
Hi @Mikihudi, @donamhung,
Quick update — this should be fixed in Zotero plugin 1.1.0. When you’re connected through the local Zotero app, citations should now show the date instead of (n.d.).
Please update the plugin and let us know if it still happens. Thanks!
