Zotero plugin adds author to reference every time a citation is inserted
Do you want to: Report a bug
OS version: 15.7.3
App version: 9.2.0
Additional information: Every time I insert a citation from the same source the associated reference/bibliography is updated by adding the author to the reference again and again. For example, if I insert a citation 2 times, the author is added an additional 2 times to the reference/bibliography so the author is repeated 3 times. Even with only one insertion the reference is updated with an extra repeated author.
This only happens through the plugin. When exporting citations directly from Zotero, they are structured correctly.
Any relevant details about the situation.
Two inserts:
One insert:
Hello @TsukiNoMegami
Can you provide a video demonstration of your actions that lead to this behavior? Also, please share the version of Zotero plugin itself (find it in Plugins tab > Plugin Manager > Zotero > Info & Support).
