ONLYOFFICE Mobile: Documents
Device: Motorola Edge 40 Neo
OS version: Android 15
App version: 9.1.0
Mode: On Device
Could You please consider setting fit to width as default for both Print and Mobile View (or set that Print zoom do not impact Mobile zoom)? Right now, if I change to Mobile View, it’s really small (so I have to zoom to be able to comfortably see the document), but when I want to change back to Print View (desktop) it’s zoomed - It’s not a huge issue, but quite irritating if someone is using both views quite often.
If something is unclear, please feel free to contact me.
Best Regards,
dedoci
