Description
Word goal plugin for document editor helps tracking your writing progress without a need to check document stats from time to time.
This plugin was suggested here:
There is not much to talk about, just a visual representation of your writing progress that is available on the left toolbar. You do not need to put your hand on a mouse or trackpad and click on stats just to check how much words in the document.
Just a single note:
After setting up custom goal, it will be saved for other opened/created documents afterwards.
Issues
- Plugin counts words specifically, Asian languages symbols aren’t supported as of now.
All installation guides for Desktop Editors are mentioned in README of the repo.
If you face any issues, you can either post them here or open actual issue on GitHub.
