Windowed Presentation Mode For Slide Shows
I have switched to OnlyOffice from LibreOffice today because the compatibility seemed way better. One thing I would like to see in the Desktop app right now though, is the windowed presentation mode which did exist in LibreOffice.
This feature was to view a slide show in full screen but as if the screen was the window it was opened in. With this feature available, I was able to look at the presentation on one side of my screen, and whatever I wanted to look at on the other side of the screen. This might sound a little confusing so I will provide example screenshots.
This is quite useful for multitasking especially while studying so hopefully this request gets some attention.
Note: I could still make use of OnlyOffice to achieve this functionality when I remove the right/left/upper/lower panels from the “view” settings, but then I could argue that some slides have those “Insert …” buttons that show up if you are not on slide show mode (will provide screenshots for that as well), I also don’t always want to waste time setting up the panels according to my preferences.
SCREENSHOTS:
example user interface look when this feature is enabled and used for multitasking:
example user interface of OnlyOffice when all the panels are removed but the “insert” buttons still exist in the middle of the slide because technically we are still editing (follow the image link if the image seems janky):
Hey @kingsoul :wave:
Thank you for sharing your suggestion and detailed explanation! I understand your idea about having a windowed presentation mode in the Desktop app.
I’ll check with my colleagues regarding the possibility of such a mode in our editors. As soon as I have any updates, I will get back to you.
Hello @kingsoul, :wave:
We’ve logged your idea for a windowed presentation mode in ONLYOFFICE Desktop Editors for further consideration.
I’d love to provide a timeline, but we don’t have that information yet.
We’ll notify you as soon as we have updates about a version including this feature.
Thank you for yourcontribution! :hugs:
