Hi, I am not sure if this is a how-to question or an actual bug.
In all of my other apps (Adobe, Chrome, Finder) opened right now, I have no problem right-clicking anything, but in ONLYOFFICE desktop it seems to be completely disabled. No matter what I try (including actual right-click, holding ctrl button, etc) when trying to right-click a column or column letter to simply insert another column, the only thing that happens is that the little hand select tool appears and then closes into a fist…
Sadly, there appears to be no option in my insert menu either to just insert a column or a row. I thought maybe I just needed to modify something in settings, but no option there.
I feel really silly, I just downloaded this app an hour ago and I feel like these are rudimentary things I shouldn’t be having trouble with but I am. How can I fix this? Thanks in advance for your help.
Macbook Pro 2017, macOS 13.7.5 (22H527), Intel Iris Plus Graphics 640 1536 MB
