When i convert docx to pdf with use of docbuilder then RTL text convert to LTR
@Alexandre
  • So simply i convert my docx to pdf with below docbuilder file
    When using bullet list, number lists its showing in left side instead of right side in Hebrew language.
    builder.OpenFile("D:/MedQTech/backend/tmp/output.0_7056223521300335.docx");
       builder.SaveFile("pdf", "D:/MedQTech/backend/tmp/output.test.0_7056223521300335.pdf");
     builder.CloseFile();
  • My docx content is RTL as you can see in the image
  • But after convert this docx to pdf my pdf bullets. number content show LTR
  • can you suggest how i can fix this problem ??
  • In this case the language is Hebrew , and my document server version is 9.0.3
normally i face same below issue
but after convert docx to pdf [ so may be issue with pdf editor]
Hello @chandani
Please attach a test file (original docx file before conversion process), we will check it out.
2148_2-Nelipak SH-BT_01425_1_2025110413(UTC+02_00).docx (355.2 KB)
I used Document server v.9.1, all things look good. Please update your installation to the latest version.
Thanks
I’ll try with latest version
Thank you, please let us know if you face any issues.
