ONLYOFFICE Mobile: Documents / Projects / Web Editors
Do you want to: Report a bug
Device: iPad Air m1
OS version: iOS 17.6 (and 26)
App version: 9.0.4 (1117)
Mode: On Device
When using the hardware keyboard to scroll around worksheet in iPad app, cursor will scroll of edge of screen, rather than worksheet moving with cursor. The worksheet must be moved manually using finger or pen to see cell being edited.
In my case, it’s the Apple Magic Keyboard with trackpad. When I cursor down through a worksheet, the cursor will continue to go down off the screen, then I need to use my finger or the trackpad to move the worksheet down to match where the cursor now is. It doesn’t track with the cursor movement like the Linux or Mac version.
Here is an example using the sample spreadsheet. As you can see, I cursor down using the hardware keyboard controls, and cursor goes off the screen. I need to use the trackpad to manually move the worksheet to find where the cursor is.
Thank you for the video. I was informed that this behavior is a bug. Your query is collected and added to the bug. I’ll provide an update once it becomes available.
