Updating links warnings, too much
Imported from UserVoice
Author: T.
So my problem is that whenever I open an xlsx file in OnlyOffice, I am “warned” about external links: “this workbook contains links to one or more external sources that could be unsafe. if you trust the links, update them to get the latest data.”. So I wanted to turn that warning off.
Under “Data” I go to “external Links”, in hopes of find a setting to stop warning me. I found the setting! Just enable “Automatically update data from the linked source” and the external sources are found above. Great. Now when I open it, I get a different message, warning me that “this workbook contains links to external sources which update automatically. this might be unsafe. if you trust them, press continue.”
Why have another separate warning?! This is a little crazy. I open this file every day to update things. Hopefully you guys can fix this. I understand privacy and security but I checked the box. I did my due diligence. Why is my software limiting my productivity like I am a little child? Thank you for your consideration.
