ivan
25 April 2026 01:48
1
Hello!
I have been using this code for a while to get a bearer token to then delete a file by file ID.
curl --request POST --header “Content-Type: application/json” --data “{“username":"xxxx@forscotland.com ”,“password”:“xxxx”}” “https://forscotland.com:6443/api/2.0/authentication.json”
And the token response used to be in the body.
Now I just see
{“count”:1,“status”:0,“statusCode”:201,“response”:{“token”:null,“tfa”:true}}
It seems I authorize OK, but no token comes back.
The Document server has global MFA enabled including for the xxxx@forscotland.com user in the POST.
I recall 3 years back seeing something similar.
Do I need to alter the POST to get the token when the account I want the bearer token for is MFA protected?
onlyoffice-communityserver 12.7.1.1942
onlyoffice-controlpanel 3.5.4.541
onlyoffice-documentserver 9.3.1-10
Ubuntu 24.04 LTS
Many thanks for any pointers
Hello @ivan
I believe you are using Workspace, thus I’ve changed the category of this topic. Feel free to correct me.
ivan:
“username"
Try specifying it as userName with a capital N.
ivan
14 June 2026 03:34
4
Hi Constantine… grabbed soem time to look at this again… still no joy with son=$(curl -k --request POST --header “Content-Type: application/json” --data “{“userName":"onlyoffice@forscotland.com ”,“password"xxxxxx”}” “https://forscotland.com:6443/api/2.0/authentication.json” ) …………… I get this still % Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 143 100 76 100 67 100 88 --:–:-- --:–:-- --:–:-- 188
json={“count”:1,“status”:0,“statusCode”:201,“response”:{“token”:null,“tfa”:true}}
ivan
14 June 2026 03:50
5
I’m using TFA on the onlyoffice account…. how can I setup PAT for the onlyoffice account (fixed code) I can use? Not perfect security wise I know…
This is workspace as opposed to Docspace
Thanks
ivan
16 June 2026 20:31
6
BUMP.. hi, how do I set a PAT token for an account when I have BLANKET TFA for all accounts on the workspace server? P.S> ALL SW is current release
ivan
18 June 2026 19:07
7
I just added my INTERNAL network to TRUSTED networks under TFA advanced settings, that way TFA wasnt needed and I got my tokens… thanks. Please close.
system
Closed
19 June 2026 07:08
8
This topic was automatically closed 12 hours after the last reply. New replies are no longer allowed.
