Unable to Connect to RabbitMQ during onlyoffice installation
I can see the RabbitMQ in my localhost and the service is running.
Unsure how to get past this.I did install RabbitMQ and Erlang as as admin and also onlyoffice as admin. Thanks
Nto sure how to Edit above post, but I cannot get past this screen
Hey @jeremy, :wave:
Could you please clarify — are you installing ONLYOFFICE on a completely clean machine where RabbitMQ has never been installed before, or was RabbitMQ already present on the system?
Also, could you share the link to the installation guide you were following?
Usually, there are no issues when installing on a fresh machine. If RabbitMQ was previously installed, there can sometimes be conflicts with ports, users, or old configuration.
Looking forward to your reply.
Thanks! :heart_hands:
