Imported from UserVoice
Author: Eldar Vatic
two columny for creating bilingual books, we have 2 books original and translated so option to create one book bilingual from 2 books,rgds
Author: Eldar Vatic
Thanks for sharing this! Want to make sure we scope this correctly before passing it along.
If we understood right: you have two existing documents — the original and its translation — and you’d like an easier way to work with them together for comparison.
One thing that would help: are you picturing something like viewing both documents side by side with synchronized scrolling (so you can read them in parallel, but they stay as two separate files), or do you specifically want them combined into one single bilingual document (e.g. two columns on the same page)? Those are pretty different things to build, so knowing which matches what you need would help a lot.
Thanks again for taking the time to suggest it!
