Troubles with a signature field
I’m working on my very first form under OnlyOffice, and all my fields work well except the most important one: the signature field.
I open it under Adobe Acrobat Reader on a Galaxy tab.
Whatever I try, the signature field stays blue, no way to get inside of it, or draw any signture on/in it.
I am a new user of this forum, so I cannot upload my form…
What should I do to get this field working?
Thank you
PS: english is not my motherr language, so please forgive me if my words are not exactly the good ones.
Hello @FlodAriege,
Now you should be able to upload a file. Could you please clarify: was this form created in DocSpace? What version of DocSpace are you using (is it the Cloud version)?
Does the field work on other devices? (PC, for example)
Please provide detailed description of your Galaxy Tab (OS, model, etc.)
