I used takeout.google.com to zip up my files for importing. (see below) I viewed the “Check unsupported files”, and it said that it doesn’t support the CCCommunity.zip file. Not sure why? Is there a file size limit?
I’m using docspace, I went to settings, data import, selected google workspace, and it’s not taking the zip file that Google provided me.
DocSpace expects Google Workspace data to be prepared in a specific format. After the export, each selected user folder should be compressed into a ZIP archive, and each uploaded archive should represent a single Google Workspace user. So, the issue is most likely not the ZIP file size itself, but rather the archive structure or content.
Please follow the official guide for importing Google Workspace data into ONLYOFFICE DocSpace: Migrating Google Workspace data to ONLYOFFICE DocSpace
If the issue persists after following these steps, please send us the following so we can investigate further:
- Your exact DocSpace version.
- A screenshot or the downloaded list from “Check unsupported files”.
- Confirmation of whether this ZIP file is the original Google Takeout archive or a manually repacked archive containing individual user folders;
- Browser DevTools information captured at the moment of reproduction: open F12 in your browser, go to the Console and Network tabs, reproduce the issue, and send screenshots of any errors or failed requests.
