OS: Proxmox LXC Ubuntu 24
Browser version: Safari Version 26.3.1 (21623.2.7.11.7)
Additional information:
Output of docker exec -it onlyoffice-community-server service monoserve status
● monoserve.service - FastCGI Mono server
Loaded: loaded (/lib/systemd/system/monoserve.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2026-03-18 13:38:10 UTC; 4s ago
Process: 26913 ExecStartPre=/bin/bash -c test -e /var/run/onlyoffice || install -m 755 -o onlyoffice -g nginx -d /var/run/onlyoffice; rm -f /var/run/onlyoffice/onlyoffice.socket /var/www/onlyoffice/WebStudio/mono_crash* /var/www/onlyoffice/WebStudio/core.*; (code=exited, status=0/SUCCESS)
Main PID: 26915 (mono)
Tasks: 4 (limit: 23091)
Memory: 20.1M
CPU: 1.047s
CGroup: /system.slice/docker-7e26acee2a81433259e5a4ab5a0f6ba41715ab4753926c27ac5a788ecae30074.scope/system.slice/monoserve.service
└─26915 /usr/bin/mono /usr/lib/hyperfastcgi/4.0/HyperFastCgi.exe /config=/etc/hyperfastcgi/onlyoffice /logfile=/var/log/onlyoffice/onlyoffice.log /loglevels=Error
Mar 18 13:38:10 7e26acee2a81 systemd[1]: Starting FastCGI Mono server...
Mar 18 13:38:10 7e26acee2a81 systemd[1]: Started FastCGI Mono server.
Mar 18 13:38:11 7e26acee2a81 hyperfastcgi4[26915]: WebConfigurationManager's LRUcache Size overriden to: 2000 (via MONO_ASPNET_WEBCONFIG_CACHESIZE)
Output of docker ps -a
docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
94f623bf47e4 portainer/portainer-ce:sts "/portainer" 29 minutes ago Up 20 minutes 0.0.0.0:8000->8000/tcp, [::]:8000->8000/tcp, 0.0.0.0:9443->9443/tcp, [::]:9443->9443/tcp, 9000/tcp portainer
7e26acee2a81 onlyoffice/communityserver:12.7.1.1942 "/app/run-community-…" 42 minutes ago Up 20 minutes 0.0.0.0:80->80/tcp, [::]:80->80/tcp, 0.0.0.0:443->443/tcp, [::]:443->443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 0.0.0.0:5222->5222/tcp, [::]:5222->5222/tcp, 9888/tcp onlyoffice-community-server
6833a4363c06 onlyoffice/controlpanel:3.5.4.541 "/var/www/onlyoffice…" 46 minutes ago Up 20 minutes 80/tcp, 443/tcp onlyoffice-control-panel
8d2386fa786a onlyoffice/documentserver:9.3.1.2 "/app/ds/run-documen…" 47 minutes ago Up 20 minutes 80/tcp, 443/tcp onlyoffice-document-server
cc0f9cf22a03 onlyoffice/elasticsearch:7.16.3 "/bin/tini -- /usr/l…" 49 minutes ago Up 20 minutes 9200/tcp, 9300/tcp onlyoffice-elasticsearch
4aa94f5fe721 mysql:8.0.29 "docker-entrypoint.s…" 50 minutes ago Up 19 minutes 3306/tcp, 33060/tcp onlyoffice-mysql-server
