Stop silently replacing the field separator in CSV
Opening a csv with ; as seperator should save the same format. \
Currently after changes are made OO save the csv silently replaces the ; with a ,
Hello @theking2
Please clarify the situation. I’ve downloaded random csv file and when I opened it for the first time, the editor prompted me to select a separator.
Please clarify if I misunderstood the scenario.
  1. open a csv file. (choosing a separator)
  2. change the file
  3. save the file
The old file is overwritten with a new file with a different separator.
I expect OO to remember the separator and save the file with the same separator it was opened with.
Thank you! We’re checking the situation.
Dear @theking2
We have added this scenario to internal tracksystem (bug number 67072), we have started working on it.
We will update this thread once we have something to share. Thank you for bringing this issue to our attention!
