Spreadsheets: add drop down menu to column/row height/width customization menu
Imported from UserVoice
Author: Eugene D
Makes Spreadsheets more comfortable. For example, WPS has it. Really useful.
Do you refer to Scale to Fit options? If so, they are available in Layout tab.
In case I misunderstand your suggestion, please elaborate. You can also provide a screenshot from the named processor as a reference.
