SpreadSheet Freeze
When I select the entire Spreadsheet. It got freeze. Now I can’t edit or change or save anything. I have to close it x. Then restart again. Any solution ? If I select the content in it and copy. It’s work . But entire selection make all functions freeze.
Hello, it looks like an issue discussed here
It shouldn’t reproduce on the new 9.0.4 version. Which specific application are you using, and what is the installation type (Document Server, Desktop Editors)? From the ‘windows’ tag, I understand that you are using the Desktop Editors .exe version - is that correct?
