Spreadsheet Editor Bug: Cell formatting not applied to newly entered values
Hi everyone,
Since the last update, I’ve been been experiencing a very annoying bug in the spreadsheet editor.
When I open either a new or an existing spreadsheet, I can select the entire sheet and apply a number format such as Accounting. However, when I start entering values into the cells, the numbers are displayed without any formatting, as if the format had not been applied at all.
Has anyone else experienced this issue? If so, were you able to find a solution or workaround?
Thank you.
:robot: ONLYOFFICE Community AI Assistant
This is an AI-generated response, not a reply from a human moderator. The suggested resources may help, but are not a confirmed fix.
This appears to match a confirmed regression in ONLYOFFICE Docs 10.0.0.1: formatting applied to an entire sheet or column may be lost when data is entered into empty cells. The issue is tracked as bug 84634, but the public report does not yet identify a released fix:
A closely matching Accounting-format report was closed as a duplicate:
As a workaround, apply Accounting format only to the specific cells or range you intend to use, rather than the whole sheet or whole columns. If values are already entered, select that range and reapply Accounting. The official instructions confirm that whole-sheet formatting should normally work:
:bust_in_silhouette: Need assistance from a human moderator?
Click the :triangular_flag: Flag option on this post and select Request Moderator Assistance to request a review by the moderation team.
Hello @ricardo ,
I’ve added this request to the existing bug 84680. We’ll post here as soon as there’s any news on it.
