I have cells with formulas that conditionally output nothing, like:
=IF(LEN($A1),"Yeah: " & $A1,"")
When outputting to CSV, all cells that should be empty, will output the formula as a string instead.
So I mill have a CSV with something like:
Foo,Yeah: Foo
,"=IF(LEN($A1),""Yeah: "" & $A1,"""")"
Bar,Yeah: Bar
I want and would expect:
Foo,Yeah Foo
Bar,Yeah Bar
To work around this, I now have to copy the whole sheet to a new one and paste as “Paste only values”. And export that instead. Not really workable!
It is an interesting issue that you have discovered, and it would appear that formulas on a row that reference the blank cell do not render a value during the export. Even a formula as basic as;
=CONCAT(A2,"")
yielded the same result;
Foo,Foo
,"=_xlfn.CONCAT(A2,"""")"
Bar,Bar
Which appears to be the result of a null field.
If the presence of a formula generated null is removed, then the result I could get is;
Foo,Yeah: Foo
Bar,Yeah: Bar
which looks what what you need, but because the formula is;
=IF(LEN($A1),"Yeah: "&$A1," ")
which is placing a space character after the comma, instead of null.
Maybe not the most ideal solution, but may suffice until support can allow a null result from a formula during CSV export.
before. Never had needed to do so.
But I was looking for a formula to yield null that didn’t keel-over during CSV export, which appears an exercise in futility in hindsight.
So, it would appear that you are stuck until Support can get OO to return a null from a formula during CSV export.
… I guess the ZWSP would not help either.
( Zero Width SPace → UNICHAR(8203) )
And, unfortunately, OO does not like UNICHAR(0) either.
If you don’t mind I will join this thread as well. @petervanwesten could you please share a test file where the issue occurs, along with the original file that’s being output to CSV?
Hello @petervanwesten
We confirm that the current behavior is a bug. We have added it to internal tracksystem andd we have started working on it.
Thank you for the valuable data!
Hi, having the same issue. i have a lot of data with blank formula and it is all in the csv export and is not usable. what is current status and ETA for the fix?
Hello @dora
Unfortunately, we’re still working on the mentioned scenario. I have added your request to internal tracksystem, we will update this thread once we have something to share.
