Some slides in presentations are stuck on loading
When I open a presentation, some some slides do not load. There are three cases, what happens:
a. All slides load in all presentations;
b. Some slides do not load in all presentations.
c. Some slides do not load in some presentations.
Sometimes a, b or c case happens.
I have attached a screenshot.
In the screenshot, there are cases where slides keep loading, but when clicking on them, they show only on the main presentation screen.
There is also a case in the video, where there are slides loading, but when clicking on them, slides appears, for example, same as the first one(but not on the main presentation screen). For example, if the first slide is shown, and the second is still loading and when clicking on the second one, the second one appears same as the first one. But on the main presentation screen, it shows the correct slide.
Device: Samsung Galaxy A25 5G
OS version: Android 15
App version: 9.0.4
Mode: On Device
Loading slide
Please provide a file with which the above-mentioned issues can be reproduced for reference
