Sobre DOCUMENTO DOCX
Buenas, quiero informar sobre una opción que uso mucho y que me suele hacer alguna faena que otra al intentar borrar.
En el DOCOMENTO DOCX apartado INSERTAR seguidamente CONTROLES DE CONTENIDO a la hora de hacer uso de TEXTO SIN FORMATO ocurre, que al escribir en ese campo y quiero borrar la ultima palabra pulsando en teclado el botón de borrar, lo que hace es borrarme todo lo escrito hasta el momento y no solo la ultima palabra. Me gustaria se corrija esa accion ya que no ocurre en otros campos como en PDF
Please note that the languages of communication on this forum are English and Chinese.
We have successfully reproduced the issue you described. We are currently analyzing this behavior. We will update you with our findings and a solution as soon as the analysis is complete.
Hello @Nanogoe
After internal discussion, we can confirm that this behavior is intentional and working as designed. The Plain Text content control in OnlyOffice has been specifically implemented to select all text on the first Backspace/Delete press, and remove it on the second press.
If you need character-by-character or word-by-word deletion, we recommend using Rich Text content controls instead of Plain Text controls, as they provide more standard text editing behavior.
We appreciate you taking the time to report this.
