Max1m
1
Hi,
When we edit the slide master, it is very useful to see if a layout is used or not, to remove it and make the presentation file lighter.
This option exists in Google Slide for example as you could see in the attachment.
Could it be an improvement on OnlyOffice?
Hello @Max1m
Thank you for the suggestion, we need some time to review it. Please await my feedback.
UPD: it has been registered in our internal bug-tracker as an enhancement for further development. I will keep you posted on the details.
Max1m
4
Thanks @Constantine for you feedback.
