Show futute slides in presenter mode, when using a remote control
Imported from UserVoice
Author: Job Zwiers
When in powerpoint presenter mode, there is a column on the left showing some slides to the presenter. Unfortunately, after going through the first few slides, the “current” slide is shown at the bottom of that left column, so one sees no “future” slides anymore. With only a remote control, one cannot “scroll” the column.
Suggestion: have some mode where the “current” slide is always showing in the midst of the column, so some past slides and (in particular) some future slides are always visible for the presenter.
