i can not find a : “Select All” option under the File ?
Is it somewhere else or it is not available ?
Hello @Molar
What is your goal? I do not quite understand what referenced “Select All” in Files tab should do – do you have any examples?
Thank you for your reply.
Let’s say I have type my document. There is a lot of text in it already and I would like to copy whole this text.
What I remember from other text editors it is possible with right to chose :
Select All and copy whole text.
It is possible even here in the window were I type text right now.
Unfortunately it is not possible in OnlyOffice document editor.
At this moment it would be very handy for me as I have a problem with mouse selection. My mouse does not work properly for some reason so it is extremly difficult to select the text by using a mouse .
You can select all document with a simple shortcut CTRL + A. Copying also has a shortcut CTRL + C. You can find the list of available shortcuts for document editor here:
