Select a column of text
In OO Documents how do I select a column of text? Alt+Select does not work.
Hey @theking2, :wave:
Thanks for the question! I’ve attached a short video below showing how column selection works in ONLYOFFICE Documents (Desktop Editors). (without Alt)
If this is not what you meant (e.g., you want to select an entire table column, or something behaves differently on your setup), please describe in more detail what exactly you’re trying to achieve.
Screenshots or a short video of your case would be super helpful too — just upload them here. Thanks!
Thanks so much. Nice!
But I was looking for column select in Document not Spreadsheet.
Thanks for the clarification!
Sorry, I misunderstood earlier — you’re looking for column selection inside a Document (text document), not in a Spreadsheet.
Could you please describe in a bit more detail what exactly you’re trying to do?
A short video or screenshot showing the desired result (and what currently happens when you try Alt + drag or other methods) would be very helpful for me to understand the exact scenario. (mb in other editors)
Thanks in advance :hugs:
Thank you very much for your question and for sharing the video example.
This request has already been registered in our internal tracker, and I’ve added your case to it as well. Unfortunately, I can’t provide an exact ETA for this at the moment, but we’ll be sure to post an update here as soon as we have any news.
