Scaling
how do i make the scren readable? The zoom factor is off.
Hello @theking2
As I can see from the screenshot resolution, you have HiRes monitor. Have you tried setting up scaling options in the settings of Desktop Editors? For instance, something like 200% or such.
Thanks for the hint. The setting was on Auto. Which seems not to detect all screens.
Did you manage to set correct percentage?
It’s a bit trial and error as I switch between wide screen hires monitors and the integrated on my laptop. but I’ll manage
