Do you want to: Report a bug
OS version: Ubuntu 24.04.4 LTS | Linux 6.17.0-14-generic x86_64 GNU/Linux
App version: Community version 9.2.1.43 (x64 deb)
Downloaded from: ONLYOFFICE website, installed via dpkg -i
Additional information:
When using File>Save As and changing the format, the file format menu at the bottom right seems to register duplicate clicks and will flicker open and closed a couple times before I can actually select a different file type, such as PDF. Also it loads a large menu with whitespace at the top. Did this in 9.0, upgraded this morning to verify still an issue in 9.2.1.43.
Behavior was consistent in X11 and Wayland and with two different wired mice that do not have “bouncing” issues on any other apps.
Can’t upload, hopefully link to screencast works: https://cloud.odinforce.net/index.php/s/oFLz8iDQEk3bMnG
Hi, @MurkyFridge !
Unfortunately, we can’t open the screencast link you shared. Could you please re-check the download link, or attach video file directly to your forum post (I’ve upgraded your user level), or upload it to another cloud storage and share a link to it.
Uploaded! Thanks!
Please let me know if you need anything else or to test anything.
Thank you for the video!
We are currently checking the situation.
We’ll get back to you as soon as we have more information.
We are currently trying to reproduce the first issue on our side. So far, we were able to observe similar behavior in a scenario where the mouse cursor slightly moves while clicking the file format drop-down in the Save As dialog, especially if the cursor leaves the bounds of the list during the click.
Could you please record a new short video with cursor capture enabled, so that the mouse pointer is clearly visible during the reproduction? This will help us confirm whether the behavior in your case matches the scenario we are currently investigating.
As for the large blank area at the top of the format list, this is related to the GTK file dialog behavior on Linux when the drop-down list would otherwise extend beyond the bottom edge of the screen, so this part is not something we can adjust from our side.
We’ll continue checking the first issue once we have the updated video.
