Retain Calc Formula Formatting
Having finally fallen out of love with Microsoft apps I’m quickly making the transition Linux and especially to OnlyOffice. Being a bit of a data monkey I love that OnlyOffice is keeping up with the array formulas, and I suspect the LET function in Calc is likely to arrive shortly.
Anyway, my suggestion is for Calc formulas. I like to use multiple rows when writing longer, more complex formulas, treating the formula more like a traditional programming language. However, on finishing the formula, Calc strips away all carriage returns and space characters. Might Calc be able to retain a formula formatted like this?
=SUMIFS(
Sheet1!$E$1:$E$100,
Sheet1!$A$1:$A$100,“Country”,
Sheet1!$B$1:$B$100,“Latest”,
Sheet1!$C$1:$C$100,“Sales”
SUMIFS(
Sheet1!$E$1:$E$100,
Sheet1!$B$1:$B$100,“Year Ago”,
Instead of reverting to this:
=SUMIFS(Sheet1!$E$1:$E$100,Sheet1!$A$1:$A$100,“Country”,Sheet1!$B$1:$B$100,“Latest”,Sheet1!$C$1:$C$100,“Sales”)-SUMIFS(Sheet1!$E$1:$E$100,Sheet1!$A$1:$A$100,“Country”,Sheet1!$B$1:$B$100,“Year Ago”,Sheet1!$C$1:$C$100,“Sales”)
I think it’s clear which is the easiest to read and edit.
Now, if you want to throw in some some color coding formats too, i.e. make all function names blue, etc., I’d be delighted :slight_smile:
I didn’t think this editor would also strip empty spaces from the beginning of each line. Assume I added two spaces before every row starting “Sheet1” in the above formula.
Hello @alinehan
We’re checking the suggestion, I will contact you shortly.
Hello @alinehan
We have added your request to internal tracksystem, we have started working on it. Thank you for your idea!
Hi Alexandre
This is exciting news. I did forget to mention in my original email, I currently use Alt-Enter to insert a new line within the formula. I imagine you had already realised that or may be using another key combo, either way I 'm looking forward to testing/using it.
