Remember Last Scroll Position When Reopening Documents
Imported from UserVoice
Author: Helton Mariano
It would be very helpful if documents reopened at the same scroll position where they were when last closed. Currently, when reopening a document, it starts from the beginning, which requires manually scrolling back to the section that was being edited or reviewed.
Best regards.
Author: Leandro Valle de Avila
ao abrir as planilhas (abas), elas voltassem onde as deixei da ultima vez
Author: José Luiz Bruni Chiessi
When one works in a document, like a book or a tutorial, that work takes a huge amount of time. So, when open a document to resume the work, it would improve it, avoiding to every time look for the page where one was working when the document was last closed. The same way, when one works with spreadsheets and one closes it in an column that is not visible initially, it would help a lot if that spreadsheet would be positioned in the column when the spreadsheet was last closed.
Hello!
Thanks for the suggestion — this is indeed a handy improvement that would save a lot of scrolling.
It’s been accepted as an enhancement (track number — 13024) and we’ll update the thread once there’s progress.
