Problems to print spreadsheets in landscape format
Hello there,
since some weeks i have the problem, that i can not print anymore my .xlsx spreadsheets in landscape format A4. I didnt change any settings, with .docx, .pdf and .pptx it works fine.
If i print the normal high orientation in A4 everything works. When i change to landscape format, my printer (Epson ET-4750 & HP Officejet Pro 9122e) give out the error, that the error message that the transmitted format size and paper style do not conform to the standard. I then have the option to print using the standard settings or to print the transmitted data. In both cases, it prints in high orientation.
Is that a known bug or is there a solution?
Using Windows 11 Build 26100.7171, all software and drivers are up to date.
Hello @NScale
Could you please reproduce the situation and record a videofile? Also please check if the print to the PDF works in this scenario
Hello @Alexandre ,
sorry for my late answer. I didnt get an notification on your reply and i just forgot to check the Thread. The Issiue is still there with Version 10.0.0.169.
What Kind of Video do you need? I just want to print in landscape format. My Printers give out the error message the transmitted format size and paper style do not confirm to the standard. In both ways, aceppt transmitted options or using printer standard, the printer is using the high format orientation and cut of the rest of the print.
