Problème formule dans calc
Bonjour, j’ai un problème avec mes fichiers calcs qui ont intégré des @ avant mes plages, faussant nombre de mes formules. Je ne comprend pas d’où vient le pb (présent dans tous mes fichiers)
Hi @Jordaneb, welcome to the community!
Please note that this community supports English and Chinese only — feel free to repost in one of those languages!
It sounds like @ symbols are appearing in your formulas automatically.
To help you, could you tell us:
  1. Which version of ONLYOFFICE Docs are you using?
  2. Were these files created in ONLYOFFICE or imported from Excel?
  3. Can you share a screenshot and a sample file?
Thanks!
Thanks for replying.
  1. I’m using the on line version for infomaniak version 9.3.1.8
  2. I don’t remember if the files were created in onlyoffice but i used exclusively only office since 3 years.
  3. I can’t download file because i’m a new user
Thanks for the screenshot @Jordaneb!
To give you an accurate solution, could you share a sample file via any cloud storage and paste the link here?
https://swisstransfer.infomaniak.com/dl/019e4fd6-852d-73c7-9ae3-fbda9df4c96a
Hi @jordaneb,
Thank you for sharing your file! After testing, we found that this behavior was improved in the recently released ONLYOFFICE Docs 9.4.
Could you try updating to 9.4 and check if your formulas are working correctly afterwards?
If the problem persists, feel free to let us know!
