Problem with Automation API in mobile pdf form filler
Hi,
Can I confirm if all Automation API works with mobile editor in form filling mode?
For example when filling a pdf form:
  • oDocument.GetFormsData(); works fine
  • oDocument.SetFormsData([…]) has no effect
    But when switched to desktop mode editor (type = “desktop”), SetFormsData will work just fine
Using onlyoffice 8.3.3.18 deployed in docker
Thanks
Hello @magnitude4808
We’re checking the situation, I will contact you shortly.
We’ve found a bug i this scenario. Thank you for the provided data!
I will contact you once fix is released.
