Problem Insert -> Table - font colour of header row set to "white on white"
Hi
OnlyOffice 9.3.1.8 on Windows 10
Using the Spreadsheet.
Suppose I create a table with some headings and some rows of data.
I can then select the block of cells which make up the headings and the data rows - and create a Table by taking the option Insert → Table.
That works fine - except that the header row text seems to disappear.
Checking I realise that the header rows cells are still there, but that the font has been set to “White” - against a “White” cell background.
Now everyone loves a white cat in a snowstorm…
Consider fixing - unhelpful behaviour in partic for anyone starting to use the Table functionality for the the first time.
Cheers
Hi @Daksol,
Thank you for the report! We tested this on our end and were unable to reproduce the white-on-white behavior you described. In our case, when creating a table with headers enabled, the header row correctly displays white bold text on a blue background — which is the default table style, matching Microsoft Excel behavior.
Could you share:
  • A short screen recording of the issue
  • Your exact version
