Problem converting to pdf
Hello, when converting a docx to pdf, if the file is 250 KB, for example, everything is fine. However, if the file is 3 MB or 150 MB, the conversion fails with the error: [userId] nodeJS - ExitCode (code=0;signal=SIGILL;error:-80)
How can I solve this problem?
Hello @Vad21im
Can you share a file that fails to convert for analysis? Also, please specify version of Document Server that you are using.
Version - 9.2.1
Thanks. Can you describe how exactly conversion is performed? Do you use Conversion API?
