Unable to print some PDF documents. What am I doing wrong?
Hello @loveshack
What product do you use: Desktop Editors or Document Server? What is the version of it?
Provide more context to the issue:
- Do you see any error after attempting to print?
- What printing settings are used?
- If it happens with specific PDFs, it is possible to share one for analysis?
Hello Constantine,
I am using Desktop Editors Community Version 9.2.0.100 (X64 exe). The documents in question are pdf bank statements, so I am not comfortable sharing them. I have tried printing 2 different bank statements with no success after saving the documents to laptop or printing while online banking. I use the same printing settings for all documents. It should be noted, that I was able to print the pdf after opening it from an email attachment. Very confusing. Other pdf’s and WORD documents print successfully. Any advice?
Thanks,
John
Since the issue produces with specific files, I’m afraid they need to be analyzed to make definitive conclusions on the cause and provide a solution.
I understand your concern about sharing such sensitive files, but I can only suggest to share it via PM for internal tests only, the file won’t be available publicly for anyone else.
