Plugins specifc to workbooks
Hello, I have just started testing OnlyOffice as a replacement for MS Office and its great to see a real alternative that is cross platform.
When I have been trying to convert VBA macros to Java Script in OnlyOffice spread sheets, I noticed there is no option for macro forms as a popup. And as far as I can tell the only option is to use plugins, which is fine, however the plugins seem to be part of the application as whole. I would suggest making plugins workbook specific to be installed from a personal or online library depending what the individual workbook requires.
Hello @LB1
Thanks for the suggestion. Unforunately, this is not feasible in terms of plugins, because they are designed to work with editors instead of specific files. I recommend visiting this topic and leaving a vote/comment for the suggestion to implement pop-ups in macros:
