Please add auto-open option for exported PDFs. A simple checkbox in export dialog would save users from manually opening each saved file
Imported from UserVoice
Author: SU - MM
Feature: Auto-Open After Export
Description:
After saving/exporting a document as PDF, automatically open the file with the default PDF viewer. This would provide immediate confirmation that the export was successful and save users from manually navigating to and opening each exported file.
Suggested Implementation:
Add a checkbox in the "Save As" dialog labeled "Open after export"
Make it a persistent user preference in Settings
Apply to all export formats (PDF, images, etc.)
Benefit:
Eliminates the manual step of opening exported files, creating a smoother workflow for users who frequently export documents for sharing or review.
