Performance Issues When Opening Large PPTX Files
Hello OnlyOffice Community,
I am experiencing significant performance issues when opening PowerPoint (.pptx) files in OnlyOffice Document Server. Here are the symptoms:
  • Large .pptx files take a long time to open.
  • The interface becomes unresponsive until the file fully loads.
  • Lag is noticeable while rendering slides, especially with images, charts, or complex animations.
Environment:
  • Deployment: Docker
  • File size: >30MB
Steps to reproduce:
  1. Upload a large .pptx file.
  2. Open the file in OnlyOffice editor.
  3. Observe the loading time and responsiveness.
Questions :
  • Are there known optimizations for handling large PowerPoint files?
  • Can server-side resources (CPU/RAM) or configuration tweaks improve performance?
  • Are there recommended limits for .pptx file size or content complexity?
Any advice, best practices, or configuration tips would be greatly appreciated.
Thank you!
Hi @greatios,
Thanks for the report! To look into this, could you share a bit more:
  • Document Server version and edition
  • Deployment — standalone Docker or integrated (Nextcloud, etc.)?
  • Host specs — CPU, RAM, and any container limits
  • Browser and version
  • File details — a sample file if possible
  • Timing — roughly how many seconds until the editor is usable, and whether the lag is on initial load or also while scrolling/editing
A short screen recording would also help us pinpoint where the delay happens.
Thanks!
