PDF viewer may not be able to display this type of document
I have an issue:
I wanted to open and edit this document :
https://www.echr.coe.int/d/application_form_nld
file:///tmp/mozilla_rapkc7490/Application_Form_NLD-2.pdf
from European Court of Human Rights
but I can not in any program I have available on my Linux computer. I get this kind of massage :
Please wait…
If this message is not eventually replaced by the proper contents of the document, your PDF
viewer may not be able to display this type of document.
You can upgrade to the latest version of Adobe Reader for Windows®, Mac, or Linux® by
visiting http://www.adobe.com/go/reader_download.
For more assistance with Adobe Reader visit http://www.adobe.com/go/acrreader.
It looks like it is : XFA-based PDF form. XFA (XML Forms Architecture) or XFA Forms are a technology developed by Adobe Systems. XFA provides dedicated templates within fillable fields, which determine the form’s appearance and layout. Usually, XFA documents are created in Adobe LiveCycle.
Do you have any idea how to open and edit it?
I have tried here : Adobe - Download Adobe Acrobat Reader
but there is no Linux verssion.
Hi.
Thank you for your message and for the attached file!
We’re checking this on our side and will get back to you with an update once we have more information.
Thank you for the provided data, we have found a bug (internal tracknumber 48256), we’re working on it already. We will update this thread once a fix is released!
