Path Error in saving or opening documents
In Linux, using Onlyoffice (Word compatible), there is a frequent path error when saving or opening a document. Here are examples. 1) When I go to the list of recently viewed and click to open, Onlyoffice cannot or will not retrieve it from the folder causing me to manually go find and open it. 2) Often, when saving a document, Onlyoffice fails to recognize the correct folder to save it into, which causes me to manually find the folder and save/overwrite the document. 3) And this sometimes results in my human error in saving it to the wrong location and down-the-road working on the wrong document causing multiple different documents and a lot of confusion.
Requesting a fix of this bug.
Thank you for reporting this.
To investigate, please update ONLYOFFICE to the latest available version first and check whether the issue still occurs.
If the issue remains, please send us:
  • The exact version of ONLYOFFICE Desktop Editors,
  • Linux distribution and version,
  • Installation method (DEB, Flatpak, Snap, AppImage, etc.)
Best regards.
