Password-protected PPT files fail conversion to PDF via WOPI Conversion API
Hi everyone,
I am testing Office-to-PDF conversion using the WOPI Conversion API described here:
https://api.onlyoffice.com/docs/docs-api/using-wopi/conversion-api/
Environment:
  • onlyoffice-documentserver-de.x86_64 9.3.1-10.el7
Most files are converted successfully, including password-protected Office files I tested, but I found two password-protected .ppt files that consistently fail during conversion to PDF.
Attached sample files:
  1. pass_1234.ppt (41.5 KB)
    Password: 1234
  2. pwd111111.ppt (131 KB)
    Password: 111111
Issue:
  • Conversion fails for these two files using the Conversion API.
  • Other test files work correctly in the same environment.
Questions:
  1. Are password-protected legacy .ppt files fully supported by the Conversion API in DocumentServer 9.3.1?
  2. Is this a known issue specific to these files or to encrypted .ppt files in general?
  3. Could you help verify whether this is a bug or expected behavior?
  4. If needed, is there any workaround or configuration required for these files?
I have attached both sample files for reproduction.
Thank you.
Hello, and thank you for the detailed report!
Since you are using ONLYOFFICE Docs Developer Edition, we have created a Zendesk support ticket for your case to avoid delays in communication on the forum and continue the investigation more efficiently.
Our team will contact you via Zendesk shortly and help you with further verification of this conversion issue.
