Is it possible to place the footer as low as possible on the page, in the right corner?
I see that currently the footer is positioned depending on where the text ends. On one page it is higher, on another lower.
Hello @Molar,
Which product are you referring to - Desktop Editors or Docs?
Desktop document editor.
There are header and footer settings on the right panel. You can change the Position – Footer from bottom value to adjust the footer’s position. The footer’s position depends on the layout settings and is not affected by the main text
