Option to disable mouse-wheel slide jumping in editing mode
Imported from UserVoice
Author: Bob Richter
When editing a presentation, I want to zoom in and scroll across the slide. I keep accidentally jumping to the next slide which is very annoying, so an option to disable the jump when scrolling with the mouse wheel would be much appreciated.
Hello!
Thank you for the suggestion.
Have you perhaps encountered another presentation editor that already provides such an option? If yes, it would be very helpful if you could share its name and a short description of how this setting is implemented there. This will help our team better understand the expected behavior and evaluate how similar functionality could be added to ONLYOFFICE in the future.
Hi,
That would be an awesome implementation. Especially for those of us making graphics and complex animations in our presentations, when we need to zoom in and move around a lot. Accidentally switching to the next or previous slide really takes some of our precious time. An example of editor with this functionality is LibreOffice Impress.
I have the same issue regarding presentation editor. I always wanted a way to zoom safely without accidental switching slides. I personally vote for some toggle easily accessible: if it’s on then we can switch between slides (the default), otherwise we are stuck with the current slide and can go to another slide just picking it from the slide list on the left.
Hello, @jvhemmer , @EmilyGraceSeville7cf !
Thank you for your suggestion and for explaining how this behavior affects your workflow.
We have found a corresponding feature request and added your feedback to it.
We will keep you informed of any updates regarding the implementation of this option!
