OpenRouter - no cookie auth credentials found
Tried various times but all the AI features fail on OpenRouter.
Also tried a couple of local AIs, including Ollama and always get ‘wrong url’ Given up on that!
Hello @IanErc
Please specify version of Desktop Editors and AI plugin. First one is available in About section of the main screen and the second in Plugin Manager > AI > Info&Support.
Also, please let me know if with OpenRouter this specific feature doesn’t work only.
It is ONLYOFFICE Desktop Editors Community version 9.4.0.129 (x64 exe). The ai plugin is Openrouter and the Openrouter API.
Thanks.
Can you check the version of the AI plugin? Also, please confirm that other items, e.g. Chatbot or Translation, work.
Version of the plugin can be found in:
None of them work. All AI fuctions come up with the same cookie error when OpenRouter is selected
The AI agent works. The issue only arises inside a document.
Ai is AI plugin version 3.2.3
Thanks. May I know which particular LLM is being used? For instance, Gemini, or ChatGPT of certain grade, etc.
